2 members (37 GC, Shade Baby),
125
Mod | | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 45 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 45 | Are the rear fenders the same size for all '47-'55 1st 1/2 ton pickups? I'd like to obtain a "dished" left rear fender for my '54 3100 and I don't want to make a mistake and get one from an earlier year that won't fit.
Finally '54
| | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | 47-55 1st 1/2 3/4 and 1 ton rear fenders are the same. | | | | | Joined: Oct 2007 Posts: 45 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 45 |
Finally '54
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | There was an article where the dimple area was marked on a regular fender and cut out and flipped inside out and welded and you had the same as the dimpled one. Sorry don't remember where I read or saw the article. May give you some ideas. Have fun and good luck Dan | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2007 Posts: 45 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 45 |
Finally '54
