| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 24 New Guy | | New Guy Joined: May 2010 Posts: 24 | So being my first full resto, I made the mistake of using a lot of reproduction parts due to the originals not being there or destroyed. well needless to say ive had my first issue. The driverside window regulator blew out after about ten uses. its broke internally while at the upholstery shop being rolled down. I had been assisting the window (by hand) from the start due to it being very tight in the felt track. Brothers has already agreed to replace it free but its only a matter of time till the pass side does it as well....
What im curious about is why its so tight and what should be done to possibly resolve this issue.
I will let it be known the window frames are gloss powdercoat so they are a bit thicker then normal but i doubt that would cause all this issue.
just bad production parts?? what should i recommend to the customer to remedy this as I will be leaving monday for air force BMT and only have this weekend after it comes back from upholstery to finish it up. just curious what people have seen or done with this issue.
thanks Marc | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've always found the windows very tight with new felt channels and needing quite awhile to wear in, I don't think there's much to be done about that part .... never had a winder fail because of it  Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The reproduction winders do not compare to the originals. On the originals their weak spot is usually the splines where the knob attaches which can be replaced. There have been similar posts here before about the quality and life of these items. I would source good originals and get your money back from Brothers.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Back in the day we always lubed the channel felt with silicone spray. Does wonders for tight fits but be careful if you're going to be doing any painting. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Most often the problem is the new glass. A lot of bolters have found the new glass was not "sized" right. Most glass shops rely on you bringing in an old glass for the pattern, and if it was not an original it could cause a poor fit. I think theres a website where you can get a pattern? Instead of silicon spray, try to rub some bar soap in the glass runs. Also the window channels have some adjustment, check to make sure thier postioned right. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Like Yakima says, some aftermarket glass is poorly sized.
Another good 'lube' is graphite powder if you can find it. It's a good alternative to the silicone spray. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2010 Posts: 24 New Guy | | New Guy Joined: May 2010 Posts: 24 | well the sub is going back to the owner today as i ship out for basic monday so ive taken it as far as i can.
as far as the issue. the glass was already in the truck but he converted to one piece door glass( no wing window) years ago so all i did is change the actual glass but that doesnt affect the felt slides because the glass doesnt make the metal frame larger or wider. I believe because i have the glass frames powdercoated they got a little tighter plus the fact that the regulators are garbage. they werent that easy even without the felt.
basically its in someone elses hands now so......
thank you for all the responses and i will forward the info to them!
Marc-soon to be USAF trainee | | |
