| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73249 02/19/2007 11:45 PM | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | I did another dumb thing and did not pay close enough attention when removing the 3 speed shift control unit that is mounted just above the steering box on the steering column. (58 Chevy, 3 speed, manual steering) :mad:
I first disconnected the shift lever and upper rod coming into the cab. On the lower rod that goes into the shift control box, there was a coil spring and 2 pieces of a rubber boot.
1. What is the purpose of this spring and rubber boot?
2. Where do they go?
I have looked in both the Service manual and Factory assembly manual and can't find anything helpful, so now I am turing to the most trusted and knowledgabe source of information.
H E L P!
Bob | | |
#73250 02/20/2007 1:17 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bob, the spring goes inside the box between the 2 pawls to keep them tensioned apart so they "click" into the slots, the boot goes on the shaft aagainst the outside box to keep dirt out
Bill | | |
