7 members (Roxxstar, Shade Baby, Hotrod Lincoln, 4 invisible), 345 guests, and 4 robots.
Topics128,156
Posts1,057,020
Members48,460
I understand that I will have to fabricate a new rear trans mount in order to make this conversion. Has anyone done this, and if so, can you give me some pointers ? Thanks in advance.
Riding in the Passing Lane
If you are changeing from a manual trans. You will have to remove or extensively modify the crossmember under the bell housing. You will need a crossmember under the back of the trans. You can buy a universal type of fabricate one. You will need to measure for the drive shaft after everything is in place & have it modified at a trans shop using the corrisponding yoke. Run a tube or hose from a vacuum source back to the modulator. If you want passing gear on a 350 you will need the cable hooked to the throttle linkage, on a 400 it uses a electric switch. You will need to change the steering column or buse a floor shifter. Run cooling tubes to a cooler in the radiator or an aftermarket cooler.
1972 Chevy c10 Cheyenne Super
Thanks for the reply on the crossmember question. I have looked at 3 sources for crossmembers, but they only have them to fit starting in year 1963 (which I believe is a different frame arrangement than the '62's. Do you have any ideas on a source for a universal crossmember to fit a 1962. Thanks again.
Pretty sure channel iron has been used, 3 inch. the X frame is real close there. A short piece is all you need. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
