| | | Forums66 Topics128,156 Posts1,057,019 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73238 02/14/2007 4:59 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I understand that I will have to fabricate a new rear trans mount in order to make this conversion. Has anyone done this, and if so, can you give me some pointers ? Thanks in advance. | | |
#73239 02/14/2007 8:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you are changeing from a manual trans. You will have to remove or extensively modify the crossmember under the bell housing. You will need a crossmember under the back of the trans. You can buy a universal type of fabricate one. You will need to measure for the drive shaft after everything is in place & have it modified at a trans shop using the corrisponding yoke. Run a tube or hose from a vacuum source back to the modulator. If you want passing gear on a 350 you will need the cable hooked to the throttle linkage, on a 400 it uses a electric switch. You will need to change the steering column or buse a floor shifter. Run cooling tubes to a cooler in the radiator or an aftermarket cooler. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73240 02/15/2007 2:34 AM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Thanks for the reply on the crossmember question. I have looked at 3 sources for crossmembers, but they only have them to fit starting in year 1963 (which I believe is a different frame arrangement than the '62's. Do you have any ideas on a source for a universal crossmember to fit a 1962. Thanks again. | | |
#73241 02/15/2007 2:48 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Pretty sure channel iron has been used, 3 inch. the X frame is real close there. A short piece is all you need. Brian | | |
