How does the strip go on...The cowl strip has a bead or raised surface on top and a channel on the bottom...the truck has a channel where the anti-squeak strip goes...so do I mate the raised part into the channel or put channel to channel ? Thanks
Hey Jimmy V , just installed mine and the raised bead goes into the recess bead channel , so when finished installing there will be a small U running in the middle of the strip that U will c. Good luck, Mike 1948 5w/sb.Cheby
Thanks alot,I really love Jaunita...it was love at first site...I have no clue how or why she sits like she does...Al I know is I like it. The PO put air shocks on the rear...I haven't put air in them to try..I'm not going to haul anything,I have my 2500HD for that. She's purely for looks. Again thanks for the comments. I now have to back out into the shop and figure out how to get snapped bolts out of the hood...50 yr old bolts and a 1/4 turn too much. Thanks
