0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Can a t-85 transmission be bolted to a 235 bell housing and if so wouldn't the shift lever be too far back (under the seat)?
ron | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | A T-85? Isn't that a stout Ford/Studebaker 3speed overdrive transmission with a non-GM bellhousing bolt pattern?
Dave | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | The T-85 was the heavy duty offering on back of the 235 in the task force trucks. Not sure if it was called a T-85, but it was a borg warner case.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yup, the T85 is primarily a Ford transmission, plus it saw duty in Studebakers and Jeeps. It is not necessarily an overdrive, that was an option on them, same as the GM transmissions. IIRC, the overdrive varaint was the T85N. The bolt pattern is not the same as GM. Better bet would be to use the SM318, as it is a drect bolt in.
Bill Burmeister | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have a correction, as Truckrolet has posted, the T85 was used as the heavy duty offering in Chevrolet and GMC trucks. That one will have the GM pattern. It is also a side shift transmission, operated from the column just like the standard 3 speed. The Jeep version is the only one I'm aware of that used a floor shift. The GM version T85 was not available with overdrive.
