8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
#731179 03/19/2011 4:01 AM
would like any info on wheather i should replace rocker panel or full length outer cab floor first. both floor supports are solid
What year/model of truck?
Personally I would replace the rocker first as i would consider this to be more 'structural'
Depending just how bad it is,I would also consider bracing the door opening too.
Got any pics?
More pix on Flickr.
Good question, I'm looking at the same thing. I have the old rocker off and the inner rocker or outer floor pan is in terrible shape. I'm scratching my head wondering just where to begin.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
its a 62 C10.the rocker has a large dent otherwise its solid.the floor has cancer along the seam where the rocker meets the pan.i apppriciate the advice
I have just abut finished doing this on both sides of my truck (66 C10, I think its easier to take off the old rocker, then do the floor, then put the new rocker on and then address the cab floor supports if needed. I didn't brace the door, and it looks like everything will go back together just fine. I did mine with the cab on the frame. Pics here:
http://s140.photobucket.com/albums/r28/meld1234/Davids%20Truck/
great !..your pictures helped. I think I'm going to remove the rocker to see just how much cancer I actually have. Congrat's on tackling that huge project. Post more pic's, I would like to see finished project.
I agree with Bigblockpickup, your photos were great and helped out a lot. Bump.
Tom
