0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How does a Corvette 3 carb setup function in comparison to a aftermarket multi carb setup? Thanks | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Depends on which aftermarket intake, and how well you choose the carburetors.
However, with most installations, I would agree with Panic.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Ok, so my next question is....how does the corvette setup work on a non corvette application. I realize it my be difficult at best to put on a ad truck. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Should work fine. It would certainly be a trick setup. I'd love to see something like that in an AD truck. The '53 Corvette's 235 made the following numbers: Horsepower @ rpm 150: @ 4200 Torque @ rpm, pound-foot: 223 @ 2400 And here's a link to see a good pic of a Blue Flame 6... http://i159.photobucket.com/albums/...20drive/ContientalBlueFlame6Corvette.jpg
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Curt's two photos show an engine that is painted a color closer to truck engine gray.
Hot Rod Dad's photo show an engine painted a little darker blue than the Blue Flame engines that I have seen (but this difference could be due to photo/lighting).
I do not gamble but I'd be willing to bet you would never get the 53-55 Corvette 3-side-draft carburetor set-up to ever fit into an Advance-Design engine bay, without serious re-routing of the steering column (and, if the truck has a 3-speed shift linkage, that would add more problems).
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You know what? I don't know. I'm going to go home and look in my AD engine bay. The one carb that looks like there could be a conflict is that rearmost carb.
Anyhow, not too many people have successfully fit V8's in these AD trucks without having to change out the steering system for something else. But I am one of them. However, as a result, my exhaust is a little odd. Shorty headers turned upside down, (pointing up), and then still needed to space the steering box an inch outboard.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | did you ever look into this?? i would like to see it done | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | This setup has been on Ebay for some time. No takers yet. Parts missing, amateurish-looking weld repairs, and a ridiculous price tag! There's probably a pretty good reason we don't see many of these on restored pickups. http://cgi.ebay.com/ebaymotors/1953...arts_Accessories&hash=item588ccfc334Jerry
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | As to whether or not the setup will fit in a truck, I cannot say positively.
As to the unit on Ebay which Jerry referenced: too bad the one choke tower is missing. There would be some additional expense in fixing the weld (weld looks like something I would do, except I learned long ago I cannot weld, so no longer even attempt welding!)
As to the price of the unit on Ebay: EXTREMELY CHEAP! These things are QUITE scarce, but most 1953~1954 Corvettes are already restored, so someone wanting the setup is also quite scarce. One day, someone will find a parts car under a haystack in an old barn missing the setup; and rip the flap off his pants pocket getting to his wallet for this setup (and no, it isn't mine; mine is significantly higher in price!).
Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2010 Posts: 9 New Guy | | New Guy Joined: Sep 2010 Posts: 9 | Curt B., I just saw this 'topic' in the engine shop and it 'caught my eye'. I don't see/hear this discussion very often. I wasn't really sure how to reply? but after reading through ,,, settled on your comment "I'd love to see something like that in an AD truck." ,,, Check out the 'mill' in my 53' on one of the 'highlighted' sites below. Not exactly a 'cookie cutter' set-up ,,, for sure!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Now that is a sweet looking set-up. What steering set-up are you using? | | | | | Joined: Sep 2010 Posts: 9 New Guy | | New Guy Joined: Sep 2010 Posts: 9 | Thanks ,,, The frame, cab and steering are all stock 55 1st series GMC, in stock position. I did notch the steering column tube directly below rear carburetor to add a tiny bit of clearance for carb drain tube fitting. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Looks great. How is the drivability? How long have you been running that setup. Don | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | good job on the carb set up.
good to know i have use for my corvette set up now. this has been one of those things everyone tells me can not be done,,,,, but now we all know better.
thanks for sharing the pics,,, if you could show more it would be great. | | | | | Joined: Sep 2010 Posts: 9 New Guy | | New Guy Joined: Sep 2010 Posts: 9 | Thanks guy's ,,, Performance is 'Great',,, very responsive ,,, A very basic and simple multicarb arrangement. I've got just over 2100 miles on this set-up. The only time I checked 'fuel mileage was during engine 'break-in' period and it was just over 18 MPG! Anyway, I think it's really 'cool' to keep it all Chevy, including the factory dual exhaust manifold (sure wish now I'd had that part ceramic-coated prior to installation),,, "Oh Well"... Wrench Fetcher, I think I have some other pic's that I'll email you, stuff that I haven't put on Photo-Bucket. John | | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | Excellent point Jerry. I know Offy makes a three carb set up for 235 Wayne head but other than than I have no experience on the issue. Corvettes of that era should be souped up cautiously.... sleepers rock! JMHO
Humble Newby
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Tom is right. I have a triple I bought at a Swap Meet in Nebraska last summer. When I got home I could hardly wait to get to work. Next stumbling block was the steering column clearance issue. Now I'm working with a Steering person who has a great reputation for finished product and we' are working on it. The manifold will get used but finding carburetor parts has been difficult. But... look, it is over 65 years old too. Normbc9 | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | what year are you putting it on Normbc9? | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Don Stocker, I had a '54 Corvette for two years and foolishly sold it to get a '60 FI Corvette. Mine ran great. Considering what time and technology was at that time ('55-59) it was really a good concept. A buddy of mine found a complete side draft setup at a Auto Swap meeting in Pleasanton, CA and took it home and installed that on a 261 he had worked over. It is still in his first series '55 Chevy 3100. It had the Power-glide behind it too and is a good combination for a street driver. If you can find one of these setup for a reasonable price I'd tell you get it. I do know a technician in my town that is a side draft carburetor ace. He has people from all over this nation sending their to him to rebuild. He has the knowledge, tools, bench set up and contacts for parts. Normbc9 | | |
