9 members (Wickedbass, Donf, TexasJim50, treegrower, sron48, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana), 49 guests, and 2 robots.
Topics128,075
Posts1,055,916
Members48,429
I have a 57 3100 V8 Truck with a later V8 in it. Bought it that way 22 years ago.
Vehicle VIN starts with V3A57Fxxxxxx
So I think that says V8 3100 1957 Flint michigan plant, 114 wheelbase 1/2 ton
followed by the Production order
I also verified that here: The VIN Buster
My engine is apparently much newer. I assume it had a 265 or 283 orignally but then at some later dat it was replaced with another V8.
It was sold to me as a 283. I thought it was a later 283 from 63 or so but the numbers I found on the passenger front flange up by the water say different:
I used this page to decipher the Partial VIN and Engine Code: Chevy Engine Code Information
Here are my numbers on the block:
10L144858 T1107CRE
1-Chevy 0=1970 L=Van Nuys California 144858-partial VID of the vehicle it came out of.
T1107CRE
T-Tonawanda N.Y., 11-Nov 07-seventh day (11/07/1970 Saturday?)
CRE - Car 1970 350CID, Tur 350, 300HP, 4 BBLs AFX (Chevelle, Camaro, Nova)
I deciphered the Engine CRE code here: Small Block Chevy Suffix Codes: CMK - CUD
I guess it was an automatic (Turbo Hydra-matic 350) - it is mated to a standard clutch and the original manual 3 speed, on the column now.
It also had the original Generator but with a Ford Motorcraft upper generator bracket on it. I am changing that out to a Chevy bracket.
Also I have put the old 57 style intake manifold with oil filler tube on it and a 2 barrel Rochester and oil bath filter (converted to K&N filter).
I still need to do something better for the PCV as my current solution is too small a hole through the intake manifold.
Does that engine decoding sound correct,from a 1970 350 car?
Looks right to me, after cross referencing with the guides I have. I show it as being used in El Camino as well, so it could technically be a "truck" engine grin.
Bill Burmeister
Ha! That is a good one! I just think it is funny that a 1970 engine ended up in it. I guess the original 265/283 must have been blowing lots of smoke or something by sometime around 1975 or 1980 and someone updated it with that engine. I bought it in 1989 and at the time it was suppose to be a fairly recent rebuild on the engine.
It was sold to me as a 283. I guess they did not know what it realy was. And I did not either as it looked like a 283 I had in a 1967 Impala as a teenager.
Well I like it just the same. Has been fun to work on and drive around once in a while. Need to get it back together and start driving it again.
