1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#731168 03/19/2011 3:25 AM
X
X Offline
On a 1965 truck, what is the best master cylinder and vacuum booster to use to go from manual to power brakes? What years and models work the best?
hat brakes are you going to use?
ron
X
X Offline
I have 1972 chevy 1/2 ton front discs and 72 rear dums (5 bolt).
Factory-correct power boosters & mounting brackets are on eBay, frequently...they are a direct bolt-on and can be done in a few hours and do not require the system to be interrupted, so bleeding is not necessary. This applies when keeping the factory drum brakes on all four corners. For the money, I do the factory fit-up, when converting, since there is only one hole, to drill, in the firewall, in order to mount the booster mounting wedge and stand-off assembly. This hole is located on the firewall with a dimple, from the factory. This is one of the first things I do on my personal trucks and I hav done a number of conversions, when doing convenience upgrades on customers' trucks.
4-5-6 Chevy truck factory power brake booster assembly
