1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#731103 03/18/2011 10:55 PM
I had my 1930 truck inspected today. The officer also looked over my 1954. He said I would need to get the engine number, transmission number and the chassis number. I can’t find the chassis number. I thought it was supposed to be neat the steering box.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Bart #731110 03/18/2011 11:19 PM
there was no trans number that matched the vin any year and no vin on the chassis in 54 - started after 55.2 when they started using the vin on titles instead of the engine number - show him your shop manual
squeeze #731127 03/19/2011 12:40 AM
Thank you. I entered my Serial number in the Vin buster and it said my 54 is a 61.
http://www.stovebolt.com/techtips/vin/vinbuster.html
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #731142 03/19/2011 1:58 AM
then you were likely using the engine number or a state assigned number, not the vin as found on the door pillar tag, see here
Bart
They did put Engine Serial No. tags on Hydra-Matic's in 54... Here is what it looks like on the truck ...
If you have a manual transmission it my not have an Engine Serial No. tag like mine ...
When the CHP officer inspected my truck in the early 90's this is what he looked for so it could be registered because the DMV said the truck had fallen of their records...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
I found the numbers that I need. The engine number on the block next to the distributor is F248284I09. It has a separate casting number that begins with GM. When I entered the number on the door post into Vin buster it said my 54 is a 61. It looks like an original tag. It has deep inset rivets holding it on.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #731312 03/19/2011 7:32 PM
is this 54 you speak of a GMC? that engine number looks like GMC [a 248], not Chev - the vin buster doesn't do GMC's
If the number you posted is right, it is a GMC motor, as Bill says. The casting number of the engine shall give you an idea of the year of the engine (looking in Inliners.org). Serial Numbers on Chevy, I don't know.
It is a GMC, that would explain why it showed it as a 61. Thak you all.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #731478 03/20/2011 5:48 AM
Bart - if you have a GMC ["New Design"] then it may well have the number stamped in the front frame rail as Chinito posted on another thread that his does
