1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I had my 1930 truck inspected today. The officer also looked over my 1954. He said I would need to get the engine number, transmission number and the chassis number. I can’t find the chassis number. I thought it was supposed to be neat the steering box. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there was no trans number that matched the vin any year and no vin on the chassis in 54 - started after 55.2 when they started using the vin on titles instead of the engine number - show him your shop manualBill | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | then you were likely using the engine number or a state assigned number, not the vin as found on the door pillar tag, see hereBill | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Bart They did put Engine Serial No. tags on Hydra-Matic's in 54... Here is what it looks like on the truck ... If you have a manual transmission it my not have an Engine Serial No. tag like mine ... When the CHP officer inspected my truck in the early 90's this is what he looked for so it could be registered because the DMV said the truck had fallen of their records...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I found the numbers that I need. The engine number on the block next to the distributor is F248284I09. It has a separate casting number that begins with GM. When I entered the number on the door post into Vin buster it said my 54 is a 61. It looks like an original tag. It has deep inset rivets holding it on. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | is this 54 you speak of a GMC? that engine number looks like GMC [a 248], not Chev - the vin buster doesn't do GMC's
Bill | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | If the number you posted is right, it is a GMC motor, as Bill says. The casting number of the engine shall give you an idea of the year of the engine (looking in Inliners.org). Serial Numbers on Chevy, I don't know. | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | It is a GMC, that would explain why it showed it as a 61. Thak you all. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Bart - if you have a GMC ["New Design"] then it may well have the number stamped in the front frame rail as Chinito posted on another thread that his does | | |
