| | | Forums66 Topics128,139 Posts1,056,756 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | Does anyone know of a stock - salvage yard sway bar that is the right width to fit a 'stange II front end ? The stock 'stange II/Pinto swaybar has the big "dip" right in the middle - it hanges lower than my crossmember ! Can't afford the Chassis Engeneering one . I sorta remember somewhere someone said a GM "G" body one fits but I am nowhere near one to measure one . | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sorry I can't offer any options Bears,but I'll be watching this thread too. Some-one will chime in soon. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I'd advise against the OEM Mustang II / Pinto front sway bar with the dip in the middle of the bar, depending on road conditions. Here is New England with all the rough roads, pot holes, frost heaves etc. we've had problems with the dip of the OEM sway bar hitting the roadway. If you live in an area where all the roads are smooth you'll be OK.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'd advise against the OEM Mustang II / Pinto front sway bar with the dip in the middle of the bar, depending on road conditions. Here in New England with all the rough roads, pot holes, frost heaves etc. Sounds familiar, just the other day I passed a pot hole and a Chilean miner was climbing out! Why does the original 'stang one have a dip anyway,is it to clear something? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | The dip is to clear the front sump oil pan on the Ford car , if I remember correctly . I have read that it would work good for the Rear sway bar , flip it over so the dip goes over the center section of the rear diff. I had a stocker on front of my truck for a while and it drove much better but caught too many roadkills ! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | The dip is to clear the front sump oil pan on the Ford car. Thanks bears. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | It won't be cheap like something in a junkyard, but I bet you can find something if you go after-market. I think what you are looking for is primarily something the right width--depending on the track width of your truck, which may not be right with the stock MII sway. Try Addco http://www.addco.net/ or one of the chassis folks like Fatman's or Heidt's. Of course you may get into fabbing the mounts a bit, but some adjustable end-links can make that pretty easy. Good luck, hope this helps.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
