1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Hi from the UK Wonder if anyone can advise me on this, as im not sure, My 54 3100 has an underbed gas tank from a 71 ford torino. it fits pretty good, but the sender unit is bad. I have brought a autometer gauge with the correct ohms to run with the ford sender, but i need a new sender. I cannot find one here in the UK ,so can i use a mustang one from around the same year as i can pick one of those up here rather tham importing one. Or any other ideas?
thanks Keith
if it ain't greasy it ain't diddly
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The best thing could be to go to a Hot Rod shop,I don't know if they have them in england,and get a universal sender of that ohm rating and then all you have to do is set the float to you're tank size.
Pete | | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | thanks for that, unfortunately the universal sender units are for bolt fixing, where mine is held in place by a lockring. Also the Torino units are in the back edge of the bottom of the tank, which means the tank has to be drained before you can get at it PITA!!!
| | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Good call, i think i will get a mustang one and have a go, shame it is not a chevy sender, it would have been far easier to work something out!
