8 members (Oswald, Hotrod Lincoln, moparguy, tclederman, 2-Ton, 1955 1 Series, Shade Baby, 1 invisible),
324
Mod | | | Forums66 Topics128,162 Posts1,057,056 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Does anyone have the specs on the transmission floor cover plate screws for 1947-55? ...I have a 51 Chev.
thanks!
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | They would have been a clutch head sheet metal screw, I believe a #12. Let me correct that they are #14 clutch head sheet metal screw not #12. Here is a picture of the clutch head screws out of my '54 transmission cover. http://www.pbase.com/dennygraham/image/133229131/large Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Cool. I'll check both. This gives me a place to start.
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Maybe my '48 is different then others. Just double checked...My originals were 1/4-20 slotted screws, replaced the ones I could get out with SS 1/4-20. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Just bought some 1/4-20 x1/2 (lowes was outta the #12's) and they didn't fit the threads ... its dark tho and there's a couple decades worth of grime on the floor. I'll give it another shot in the AM. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1/4 x 20 is a bolt ("machine-screw") thread. Try a #12 or #14 sheet metal screw as suggested by Denny. I'll measure mine tomorrow. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | See the correction that I made to the earlier reply, it's a #14 not #12 clutch head SM screw. My 1950 uses the same size screws. The '50 is an oval head and the '54 is a flat head, both of them clutch drive. http://www.pbase.com/dennygraham/image/133229131/large http://www.pbase.com/dennygraham/image/133229284/large I've never seen a nut plate in the floor board which would be required to have a 1/4-20 cap or machine screw. DG
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Cool. Thanks guys! I'll swap what I bought as soon as I get home tonight. | | |
