| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | As promised, after searching under the rocks found that Fastenal could get you the original Type AA six slotted head bolts with 300M steel for you GMC flywheel, made either by Aetna Screw or Chandler. Not cheap, 16 bucks each. Since bolts are 1/2x20 not much options. ARP's cheaper goes to $30 up to $100 (top fuel) for the kit of six in that size. You Chevy guys are lucky with 7/16 bolts. I'll go with the ARP's, but in case your restoring to exact specs or are a little bit anal on original parts, hope this is useful. I contacted Fastenal in Houston. | | |
