| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | the motor turns over but the dist.rotor does not turn. I can wiggle the rotor but not turn it. anyone know whats wrong, i'am lost. 53 216 motor. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would bet you have lost the cam gear. Pull the oil fill cap and see if the rockers are moving.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2011 Posts: 15 New Guy | | New Guy Joined: Jan 2011 Posts: 15 | Pull out distributor to check that gear & pin first (after checking rockers) & hope--it is easier.....Steve
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | If the pin was sheared, the rotor would turn by hand. I'm betting on a shelled-out timing gear. Jerry
