2 members (TUTS 59, 1 invisible),
136
Mod | | | Forums66 Topics128,090 Posts1,056,381 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 16 New Guy | | New Guy Joined: Sep 2009 Posts: 16 | Hi all, poking in again with a question:
Have a crumpled rear fender I'd like to either get repaired, or replace and swap/sell away. Been looking for original used ones, but haven't found much in condition better than the one I have now.
Plan to chop it and reverse for mounting of the spare tire on the passenger side of the truck, (I know originally this was a driver's side mount, but garage logistics prevent it) and I'm curious if the 'mfgd to OEM specs' on some parts really means anything. Fiberglass is NOT an option.
Opinions/suggested sources appreciated!
As always, thanks in advance!
michelle | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Where in Texas are you Michelle?
Jimbos59chevy sells alot of original parts out of his backyard and also has a ebay store. You can check with him. Last time I looked he had several front and rear fenders for AD pickups.
58' 3200 235 3-speed/OD
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | I was going to suggest just that! | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 |
| | | | | Joined: Sep 2009 Posts: 16 New Guy | | New Guy Joined: Sep 2009 Posts: 16 | Thanks for the quick answer!
I've checked jimbo from time to time - but either he doesn't get the rear fenders often, or they sell before I can snag one. There's one (different seller) on ebay now, but it's got a tear. The fender I have has some creases or light folds near the bottom rim. (tow damage; broke the rear axle and Mabel had to be 'rolled' onto the flatbed on the fender.)
Have been quoted astronomical sum to repair the fender, so looking for a replacement. Maybe I just need to visit more body shops. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I bought my rear fenders from a local guy that sells Dynacorn products and they fit good and look stock.I would use them on all my trucks,I'm starting a 53 GMC soon.Also the price was good to.But that was a year ago.
Go on the Dynacorn web site and they have a dealer finder,just put you're zip in.
Pete
| | | | | Joined: Sep 2009 Posts: 16 New Guy | | New Guy Joined: Sep 2009 Posts: 16 | Thanks Pete! There's a dealer in my zip code, so will try him/her tomorrow. The address is a residence though.
I appreciate the help!
~ mabel & michelle | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Just a comment about your spare going on the passenger side. It is a good idea. I had a 53 with it on the driver's side and as I was driving solo 90% of the time, my weight plus the weight of the wheel/tire made the truck lean. I ended up putting extra leaves in the driver's side rear spring. Frankly I never liked it as it seemed to be in the way. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Mine was to ,turned out to be a nice guy and I've bought alot of other parts from him.
Pete | | |
