2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
me and my dad have just purchased a 1960 apache and a 1965 3/4 ton 4x4. my plan is to put the apache body on the 4x4 use these rims and tires in a 35/12.5 15. what is your opinion on this? should i put smaller tires? what would you do with it?
http://www.summitracing.com/parts/CLM-4225008/
http://www.goodyeartires.com/tire/wrangler-mtr-kevlar/
2007 2500HD Duramax crewcab
1965 3/4ton 4x4
1960 1/2ton 2wd
Sonce you're going with a 3/4 ton chassis and I presume axles, I would strongly suggest using a 16 or 17 inch rim over the 15. You'll gain much more stability with the shorter sidewall. There's also a potential for brake interference, especially if you upgrade the front axle to a later open knuckle version, which I also highly reccomend if you pan on any off roading. The later open knuckle axles have a stronger spindle (7/16" bolts vs 3/8"), a tighter turning radius, and on '71-'92, disk brakes.
For tires, you might want to consider the BF Goodrich Mud Terrain KM. It's a much better tire than the Goodyear, and costs less, too.
Bill Burmeister
