4 members (wilbur53, burgundybolt, Jack Ryan, 1 invisible), 86 guests, and 3 robots.
Topics128,086
Posts1,056,331
Members48,442
#730211 03/15/2011 8:45 PM
Hi all, poking in again with a question:
Have a crumpled rear fender I'd like to either get repaired, or replace and swap/sell away. Been looking for original used ones, but haven't found much in condition better than the one I have now.
Plan to chop it and reverse for mounting of the spare tire on the passenger side of the truck, (I know originally this was a driver's side mount, but garage logistics prevent it) and I'm curious if the 'mfgd to OEM specs' on some parts really means anything. Fiberglass is NOT an option.
Opinions/suggested sources appreciated!
As always, thanks in advance!
michelle
Where in Texas are you Michelle?
Jimbos59chevy sells alot of original parts out of his backyard and also has a ebay store. You can check with him. Last time I looked he had several front and rear fenders for AD pickups.
58' 3200 235 3-speed/OD
I was going to suggest just that!
Haha beat ya to it Dan!
Thanks for the quick answer!
I've checked jimbo from time to time - but either he doesn't get the rear fenders often, or they sell before I can snag one. There's one (different seller) on ebay now, but it's got a tear. The fender I have has some creases or light folds near the bottom rim. (tow damage; broke the rear axle and Mabel had to be 'rolled' onto the flatbed on the fender.)
Have been quoted astronomical sum to repair the fender, so looking for a replacement. Maybe I just need to visit more body shops.
I bought my rear fenders from a local guy that sells Dynacorn products and they fit good and look stock.I would use them on all my trucks,I'm starting a 53 GMC soon.Also the price was good to.But that was a year ago.
Go on the Dynacorn web site and they have a dealer finder,just put you're zip in.
Pete
Thanks Pete! There's a dealer in my zip code, so will try him/her tomorrow. The address is a residence though.
I appreciate the help!
~ mabel & michelle
Just a comment about your spare going on the passenger side. It is a good idea. I had a 53 with it on the driver's side and as I was driving solo 90% of the time, my weight plus the weight of the wheel/tire made the truck lean. I ended up putting extra leaves in the driver's side rear spring. Frankly I never liked it as it seemed to be in the way.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Mine was to ,turned out to be a nice guy and I've bought alot of other parts from him.
Pete
