3 members (hardshell, klhansen, ShopRag), 44 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#729928 03/14/2011 10:08 PM
does anyone know the stock shock size on a 1965 chevy k20?
2007 2500HD Duramax crewcab
1965 3/4ton 4x4
1960 1/2ton 2wd
65k25 #729930 03/14/2011 10:13 PM
The top & bottom mounting points are 3/4" I.D., but I am not sure of the compressed eye-to-eye dimension or the travel length. I do have some part numbers and they are available in the correct configuration, but not many sources have current part numbers. I learned, the hard way, that they are available, but hard to locate. Shoot me an e-mail, as a reminder, and I will check my records for the part numbers.
i have seen alot of different rear suspension setups and mine is weird. it has leaf blocks which is stock but the shocks are in a weird position they go from the front of the rear axle tube and up to the inside of the main frame rails? were i have seen it it shows they go from the leaf block to a frame support. i think they migth have cut off the point on the leaf block and moved them or is this the way it is stock??
1965 3/4ton 4x4
1960 1/2ton 2wd
65k25 #730069 03/15/2011 5:52 AM
The factory location is from the forward location on the rear axle tubes to the inside of the frame rail, to a quasi-mount. The 3/4" bolt goes through the frame rail, through the mount & into the upper shock mounting eye. From top-to-bottom, they slant rearward, to the axle tube. The leaf block cross-section looks similar to a piece of train track rail with a cantilevered haunch, acting as a bump-stop. I may have a few good photos of this assembly.
Here is a link to an auction on eBay for the correct rear shocks:
Rear shocks
I have purchased & installed these and they have proven to be a good value, considering the price, fit, finish & performance.
Any ideas as to what works on the front?
maxwoof #730146 03/15/2011 4:10 PM
Part #33033 monroe on front, #32301 monroe on rear for stock length
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
The front & rear shocks for the 2wd are different than the front & rear shocks for the 4x4 trucks.
64fleetside, are those numbers for the 2wd or 4x4?
my bad Tony, I thought i read c20-monroe #34822 rear, #34944 front on k20 4x4-thats what I get for posting while @work-things tend to get crossed up...
