0 members (), 145 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
#729412 03/13/2011 6:09 AM
What is the best way to know at what point to rotate the engine to check the valve clearance.
Thanks Larry
Check the tech tips on this site.
Valve adjustment
The stovebolttech tip is good
I used Nathan Hall's instructions on Deves site.
I will note,
the stovebolttech tip sets exhaust valves at .013 (might be for a 216)
Nathans Hall's tip set exhaust at .018
all set the intakes at .006
All readings Hot
The manual for my 235(54 car without power glide) states .016 for exhaust
Consult your shop manual.
I set mine recently after replacing a bent push rod. First time I ever did it.
Made a diagram per the tip,I took as found reading and wrote them down, they were all off.
After setting correctly the truck ran and sounded 10 times better.
Good Luck
