1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
#729722 03/14/2011 4:14 AM
hi guys
sorry if this is the wrong place to ask but i didn't know where ells to post
ive swapped out my original diff for a 37 sedan diff as its top leaf mounted and will allow me to lower the truck.
but i am now having a issue finding u bolts as the ones that were on the original diff were square end but the sedan requires round ended u bolts.
so my question is what is the standard length of the u bolts in a 37-38 Chevy 1ton ive measured up how long they need to be and have some out at approximately 8" (i would be more specific but i have issues with imperial measurements) due to the 14 leafs stacked on each other.
any help would be appreciated as i think the last owner might have jammed more leafs in screwing original measurements for me
thank you
jeff
Do you have a spring/axle repair shop in your area? Take your measurements that the ubolts need to be and they can make you up a set. A lot easier than trying to find a vintage set. Had some made for my 39 Truck and they were quite reasonable. Rick G.
1939 Chevrolet Stake Truck
