1 members (delky),
74
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#7297 11/25/2003 10:25 AM | Joined: Oct 2003 Posts: 15 Member | | Member Joined: Oct 2003 Posts: 15 | I just received word that someone had a 230 exhaust maifold for sale...will this work on the 292? thanks! | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | The two engines share the same intake/exhaust port patterns so yes the 230 manifold will work. The heads are swappable between the engines. Only difference I've noticed is the location of the temp sending unit.
I believe the 292 exhaust manifolds in light duty trucks have the same 2 inch exhaust port as the 194-250 sixes. However the heavy duty truck 292s all had a 2 1/2 inch 3 bolt exhaust port. Again because the 194-250 sixes share the same intake/exhaust port patterns the 2 and 2 1/2 inch exhaust manifolds are interchangeable. But the larger exhaust will yield better airflow and therefore better performance.
-ftyler | | |
