I have my windows apart. Whats the trick for installing the four rivets for the vent window seal on the channel that is also riveted to the division bar. The weatherstrip gets riveted (4),to the channel, and then the channel gets riveted to the division bar, but the heads of the two rivets that hold the channel to the division bar are under the weatherstrip. Or do you eliminate the two rivets, and simply rivet the whole assembly to the division bar as one assembly?
