2 members (55shaker, moparguy), 72 guests, and 4 robots.
Topics128,128
Posts1,056,684
Members48,452
#729546 03/13/2011 8:01 PM
Hello. Now that it's a bit warmer I'm back to tinkering. Does anyone have any pics of the battery holder on a '36? Mine's located under the passenger side and will need to be replaced. If I could see a shot of that area, either with or without a battery, it would be helpful.
Thanks!!
Jeff
Jeff,
If you don't get a photo by the end of the week, I can send one along when my kids are back with their cameras. I just rebuilt the battery box in my '36 low cab. Does yours have a 235 in it by chance ? I'm puzzling over how best to modify the cross frames to put one in. David
Thanks David!
No, the engine is actually a '39 216 instead of the original. I'm sure that there are many people here that can answer that question for you. The Stovebolt is a great source of info!!
Also, just curious...what gauge battery cable did you use? And how long? Mine has been modified with a dash starter, so the batt cable will run up to the relay on firewall. It's a bit longer.
Thanks!!
Jeff
Jeff,
The 216 I believe is the same length as the 235 which is an inch plus shorter than the original 206. Can you tell how the cross frames were modified ?
On the battery cable, are you running a 6 or 12 volt starter ? The 6 will require a larger wire. Lenght should not be an issue going to the firewall.I just go by eye with what I have around but will see if I can pin down some actual recommended sizes.
Oops...forgot to mention that I'm going with the original 6V system. An 80-yr-old friend of ours said we need to go with "double-ought" gauge batt cable or it wont start well. He was a mechanic on these old trucks when they were still on the road!
Let me look thru my pics and check on the cross frame. If I don't have a good shot, I'll get one. From the looks of it, whatever mod that may have been done was done a very long time ago.
Jeff
Thanks. Send me a PM if I forget to get you the photos of the batt. box this weekend.
He's right on the battery cables--the heavier the better!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
David,
Hi. I sent u a pm earlier. I have a few shots of the crossmember for you. I can e-mail them to your e-mail address, or download them here.
Jeff
