Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (66flea, delky, dt235sd, TooMany2count), 149 guests, and 4 robots.
Topics128,277
Posts1,058,447
Members48,490
How hard is it to replace the pitman shaft bushing?
Can I just pull out the pitman without messing with the steering shaft?
The box adjusted up just fine but the pitman shaft end moves just enough to make it a serious effort to keep the truk in the correct lane.
Thanks, John
Nope, unfortunately, the output (Pitman) shaft is the last thing you take out of the box on a complete disassembly. Some boxes have a bushing, while others have a needle bearing in that position. I'm not sure which one you're likely to find in yours.
Took it to a local shop they cleaned it up and replaced the output shaft bushings and adjusted it. Made a substantial improvement in my ability to keep it on my lane of the road.
John, Do you have any photos of your COE, anywhere on the web.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Only photo of my truck on the web is at HOTRODGARAGE.NET
Look for stock# 1155 under the SOLD heading. Thats before I cleaned it up.
I will try to send you a photo by email and you welcome to post it anywheres you like. I`d post it here but I`m not that talented. I did get it driveable and registered two weeks ago but theres still lots to do. Biggest issue I`m dealing with is a leaky rear main seal and re assembling the doors. Those flexible window channels arent that flexible and are turing into a real Bicth.
