| | | Forums66 Topics128,175 Posts1,057,119 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | The 216 engine in my 50 chevy has a block casting number "GM3 3835849" and a head casting number "GM3835517". These casting numbers apparently refer to a 52/53 216. When I unbolted a connecting rod, I found that it has insert bearings and not babbitt. Did the 216 ever come with insert bearings? Maybe in 53? I did see some Internet references to a kit, from long ago, for converting from babbitt to insert. Also, as a side note, the engine serial number "DR140622CAL" doesn't match up to any Chevy 216 serial number prefix data I could find on several Internet sites. Just trying to figure out what I have.
| | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | The splash oilers can be modified for inserts so if you still have the dippers and oil trays its a 216. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All splash engines, whether a 216 or early splash 235, came without insert rod bearings. It is common practice to convert to insert.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Here is a link to a previous thread about converting an early 216 or 235 to insert bearings, or even pressurized lubrication for the rod bearings, as one member is planning. Note that when Chevrolet first came out with full-pressure, insert rod bearings, the actual bearing material was still babbit metal. It was no longer spun (or poured, in the real old says). Hoyt | | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Based on the input I'm getting from this and other forums, I'm starting to think that this engine was converted from babbitt to inserts. Also, based on the casting numbers, I'm thinking the engine is probably a 52'/53'. I'm learning a lot as I go along! | | |
