2 members (NJC, greenie-reddy), 159 guests, and 4 robots.
Topics128,260
Posts1,058,287
Members48,485
#728990 03/11/2011 10:59 PM
I'm looking at a IFS for my chevy truck. The guy has it listed for a 1948 chevy truck. He says he doesn't know if it will work for my 1949 chevy truck. Is there any differents in the frame rails on the trucks from 47 to 53 ?
There are some very minor details/differences I've seen on the 2 tons, but as far as I know everything that matters is interchangeable on frames for 48-53, both big and small trucks.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #729154 03/12/2011 11:59 AM
half ton and 3/4 ton frame rail stampings are the same. minor changes to brackets for cab mounting, radiator mounting, etc. however the frame rails are the same.
The 3/4 ton frame is not the same. If not then I got a 1 ton setting in my garage. Half ton (Y's) out after the cab and the 3/4 ton goes straight back. The front is the same but the rear where the springs mounr are different, like I said unless the one I got is a 1 ton. I bought this other frame because my 1/2 ton was too rusted. This frame is heavier and longer but I was just going to shorten it to fit a 1/2 ton. Look in a shop maual and check.
AD frame rails 1/2 ton '48-'53 are the same. The "54 1/2 ton frame is slightly different, but the front part is the same.
3/4 ton frame is entirely different and so is the 1 ton frame.
So you have 3 different frames, in width, length, frame rail height, rear spring mounts, area over the rear axle etc. Cab mounts are totally different on the '48 also.
