5 members (Lightholder's Dad, Paul Mullen, Gray_Ghost, TUTS 59, Wally / Montana), 210 guests, and 2 robots.
Topics128,077
Posts1,056,019
Members48,433
#728964 03/11/2011 9:28 PM
Guys-
It has been a LONG time since I've posted, and I had a quick question. I was looking around under the rear of my truck (54' 3100) the other day and noticed something I had missed before. I have the standard leaf springs, and I also have coil spring that sit on top of the axle (welded, just a dime sized tack) and under the frame. At first glance my guess is that this is something ol' farmer fred tossed in there so that the truck wouldn't bottom out quite so badly when he had it full of manure. Especially because it didn't have a legimate spring perch. Any thoughts?
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
Bryan Buser #728967 03/11/2011 9:39 PM
Yep, shade tree overload springs! If they're welded, particularly if it's at both ends, they will break off eventually. I'd suggest jacking the rear end up to relieve as much tension as possible, and use a cutoff wheel on a small hand-held grinder to remove them. It's not uncommon to get some frame bending at the top side if the load gets heavy enough- - - - -without a spring perch or a crossmember, that spot's not designed to carry suspension loads!
Yup right,aftermarket overload springs,very popular years ago.
dale937 #728989 03/11/2011 10:58 PM
nice.....
Thanks guys. I'm hoping to toss in a drop axle and lowering blocks later this summer, and those coils were going to be in the way. I think about 4" should be just right.
Bryan
