8 members (51sub, 55shaker, Hotrod Lincoln, mason86, Paul Mullen, Peggy M, walter74, Bill Hanlon), 78 guests, and 0 robots.
Topics128,050
Posts1,055,680
#728936 03/11/2011 7:50 PM
I have the axles out of my 46 1/2ton. One brake assembly looks like diff fluid leaked. In the shop manual it says a special tool is needed to drive in axle bearings - but for the seals is says quote: "the oil seal should be staked in place with a [censored] punch". I don't want to replace the bearings, but as a percaution, I'd like to replace the seals. Can I cut/pull the old seals out, leave the bearings as is, and then push new seals in? Or am I creating possible problems? Thanks!
Riding in the Passing Lane
Yes. You can do it exactly as you descibe. You do not have to stake the seal. Its not going anywhere. If the bearing looks good & the axle has no pits on it you are good to go. I take it you have the axles out already. If you have grease on the brake shoes you must replace them. There is no way to clean them.
1972 Chevy c10 Cheyenne Super
Thanks! I was thinking it should be OK, but wanted to double check. Thanks.
I just pulled the drums off my '46 one ton and it looks like I have more oil in the drums than in the differential. Do you have a picture of what the oil seal looks like if that's what I need to replace.
I'm sorry I don't have a picture. I ordered 2 from Obsolete and received last week. They were in waxed paper. Just opened them - they are a circular metal "U" channel with a rubber seal inside the channel that sticks up a bit beyond the metal channel. To see them on the truck the axles need to be removed. That was actually a easier than I expected. The steps in the shop manual to remove the axles worked step by step (just a mess with the diff oil).
