4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#725396 02/28/2011 10:52 PM
I started to get my speedometer sensor hooked to the tranny (350 turbo) and don't have enough room between tranny and exhaust. It's a 59. Is there a 90 degree adapter for this sort of thing? Really didn't want to pull the exhaust,but may have to. I'm using Dolphin brand. Called them, they weren't much help.
Thanks, Mike
I've never heard of a 90 adapter for this application.
Sorry,but it sounds like you'll need to modify the exhaust.
Just how tight is it?
At first I wondered if you could 'dimple' the pipe but if it's that close,heat might also be an issue.
More pix on Flickr.
contact D&D speedometer in the twin cities, or the speedometer shop in Milwaukee. they make a 90 degree adapter. also, there are in-line VSS's from Jagsthatrun.com
I stand corrected...thanks Scott.
More pix on Flickr.
Check PATC -
90 deg speedo adapters
regards,
Leon
D&D custom makes adapters in a variety of ratios as well http://www.ddinstruments.com/index....y&layout=blog&id=5&Itemid=57
Speedometer shop
http://www.speedometersolutions.com/speedometer_cable.htm
and of course - Jags that run. note that JTR is less expensive than anyone else (pure volume)
http://www.jagsthatrun.com/SpeedSensors_Order.html
I bought an autometer electronic speedometer and it busted after 1 year. I hope you have better luck.
Of course with nearly everything made in China now, it's anyone's guess.
Thanks for the information guys.
Mike
