2 members (66flea, 1955 1 Series), 98 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#727748 03/08/2011 12:02 AM
1 Offline
im looking at putting new tires on my truck, its a 53 1/2ton on a 1964 4x4 frame.since the truck is a hybrid of the two,is their a way i can measure the size of tire that i can fit under the truck?
If by chance you have the 64 wheels currently on the truck your local tire dealer will be able to give you some viable tire size options.
Summit Racing sells a measurement device that is attached to the hub that gives you an idea about backspacing, offset and tire aspect ratio if you don't currently have rims. It's pricey but so is guessing wrong and having a set of wheels and tires all mounted up that won't fit and you can't turn back in for a refund.
Getting proper fender/frame/tierod clearance and the "right" look for your ride is often under-estimated in importance. With the combo you have, you'll probably have a problem getting specific info that will solve your application difficulties.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
In stock form, the '64 4x4 wll clear 33x12.50x15s no problem.
Bill Burmeister
