7 members (2-Ton, Shaffer's1950, Otto Skorzeny, Gdads51, stoveboltgator, klhansen, Rusty Rod),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | hi all, on my 70 c50 there is what looks to me to be an aftermarket rear axle controller. I should have taken a picture, but don't have it yet. Anyway, it is a small black box app 3x5" that has 1 hose going into one end and 2 going in the other with essentially a choke cable coming from the shifter to the box. I have not had a chance to trace all the hoses, but it looks like the 2 go towards the rear axle and the one comes from the front. I know, pretty pitiful info for you, but i wanted to ask while i was thinking about it. My question is, has anyone else seen one of these, and is the operation going to be the same as the original? I'll try to get a picture of it if it is light enough when i get home.
thanks
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy macgyver, as you said it sounds like an aftermarket control, I would think if it was made to replace the o.e.m. one then it would perform like the o.e.m. one. About the only way to test it would be to fire the truck up and see what happens when you try to shift the axle. It may not work, but then you could trace down what is actually not functioning. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Sounds like the stock vacuum switch setup used from 1955 2nd and up. Is it mounted to the top of the transmission on the drivers side? The ones I've seen have 4 hose ports. 3 large and 1 small. The 3 large ports are for Main Vac Supply, Hi to the rear and Lo to the rear. The small port connects to the 2-speed adaptor on the back of the speedometer which keeps the speedometer in calibration when you shift the rear from Hi to Lo and back. All of mine are natural metal color, not black, but yours could have been painted at some time. Pictures will help... Mike B  | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | thanks guys, setting here at the computer, i honestly can't remember what it really looks like, every time i have been under it i was working on something else like the brakes or exhaust, so i wasn't focusing on it. i planned to get pics but ran out of daylight last night, i got distracted on my 37 finishing fabricating motor mounts. I'll get a picture of it so we can quit guessing. jason
1937 GMC T16 468 BBC th350, 4.10 1941 Dodge COE 5.9 cummins, 9 speed roadranger 1947 Diamond T COE, hercules and 4 spd, all original 1955 Chevy LCF 9.0L IH diesel AT545 1962 Corvair (Elsie) 1967 Jeepster Commando 1968 K10 1970 Chevy C50 box truck | | | | | Joined: Mar 2005 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 68 | ok, i finally got a few pictures of it, there are 3, and this is the first one: http://s1229.photobucket.com/albums...ck/?action=view¤t=DSC02105.jpgis the small tank an accumulator?
