1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#728021 03/08/2011 9:53 PM
I fixed my headlight switch, thanks to info from Bill and Marty, but now I have another conundrum.
One low beam was burnt out. I went to NAPA to get a replacement. All they had was halogen sealed beams. I bought two.
My question is: do halogens use any more power than the old sealed beams? These are 35W bulbs. Will using them cause the bi-metal breakers to heat up?
"Happiness equals reality minus expectations" - Tom Magliozzi
I'd say they'll work OK, I've had halogens in otherwise stock ol trucks, but you coulda told NAPA to get you some originals, they're still in the system .... I always keep spares on hand for all the different lights
I've been running halogens without relays in my '56 for several years with no problems.
To answer ur question. Only if the wattage on the new bulbs is greater than the old ones.
Now I doubt that they are, most replacement bulbs or seal-beams are of the same wattage even though the new bulb happens to be halogen.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Don't know if this will help or not but 35 watts in a 12 volt system equates to about 3 amps, double that for the 2 headlights and they will be pulling right at 6 amps.
