| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I fixed my headlight switch, thanks to info from Bill and Marty, but now I have another conundrum.
One low beam was burnt out. I went to NAPA to get a replacement. All they had was halogen sealed beams. I bought two. My question is: do halogens use any more power than the old sealed beams? These are 35W bulbs. Will using them cause the bi-metal breakers to heat up?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd say they'll work OK, I've had halogens in otherwise stock ol trucks, but you coulda told NAPA to get you some originals, they're still in the system .... I always keep spares on hand for all the different lights
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've been running halogens without relays in my '56 for several years with no problems. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | To answer ur question. Only if the wattage on the new bulbs is greater than the old ones. Now I doubt that they are, most replacement bulbs or seal-beams are of the same wattage even though the new bulb happens to be halogen.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Don't know if this will help or not but 35 watts in a 12 volt system equates to about 3 amps, double that for the 2 headlights and they will be pulling right at 6 amps. | | |
