| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Hello, I have a 55.2 Chevy truck with a late model wiring harness. I'm new to electrical wiring. I have a question about grounding. Is there any benefit to routing ground wires from various components through the firewall and making one connection that has a strap to the negative battery terminal? Another words a direct connection rather than using the body to ground. Even though I have the cab, frame and engine directly grounded via straps. You can see how I have it with the diagram link below. Electrical diagram | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Technically what you are doing is bonding from battery to ground ie starter frame firewall. Looks good to me drawing wise. I would use at minimum 2/0 in either 12 or 6 VDC for starter ground - go there first then you can have a bond from starter ground point to cab or you can run this bond separate from battery bond to the frame on the way to the cab. This one I would do in # 8 or so maybe # 6 if you have lots of load ie 130 dBA sound system
Dan Bentler
Dan Bentler | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there is no advantage [beyond redundancy] to adding any more ground wires than the factory had, neg post to firewall right behind battery and starter mount bolt to toeboard boss - electricity travels thru any conductor instantly and having more paths doesn't improve anything .... just make sure the connections are tight to start with and keep them that way Bill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Dan, You lost me on the "2/0 in either 12 or 6 VDC" thing.
I guess I wasn't thinking "redundancy" but "reliability" on this. It seems like if you get some rust on a grounding point over time it shorts out. If it were all in one place (right behind the batter on the firewall) it would be easier to maintain.
I'm over thinking this aren't I? I do that a lot. That's how I drift off to sleep at night...how can I make this more difficult? Ha, ha! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, overthinking - use good star type lock washers to insure contact thru the paint on the cab and you'll have the reliability the factory engineers provided .... I'm kinda skeptical you'd waste all the effort you've been putting into that truck for any problematic corrosion to happen in your lifetime  also, adding more connections doesn't make anything easier to maintain, the simplicity of this retro-tech allows for ease of trouble shooting Bill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Thanks for setting me straight Bill! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Please allow me to set you straight on another matter. A corroded ground point does not "short out", it looses ground. "Short" is a term meaning a short circuit. When power finds it's way to ground before reaching it's destination, that is called a "short". When power does not find it's way to it's destination or when an intended ground does not find it's way to ground, that is called an "open", for open circuit. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Like when I hooked up my volt meter, forgot to scrape off the paint where the ground wire was hooked up to, turned the ignition key and fried the ground wire?
I knew it was a four letter word, but I didn't think was "open" for open circuit!
Thanks for all the info.! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The point that Cletis mentioned seems to be the most commonly misunderstood fact of life in the wiring world. | | |
