0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | can anyone please send me a simple wiring diagram/understanding of the wiring (2 wires) for a 51' stock gas tank sending unit? my truck had no wires when i got and the new unit came without instructions. seems pretty simple, i just can't find it any where online and i don't want to hook it up wrong. thanks -DVZ | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 51 truck wiring diagram, print it out, should also be in the shop manual, an invaluable asset for vintage truck owners Bill | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | bill, thanks so much. i know i need to get a manual. -DVZ | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | i hooked up the unit the way the diagram shows and am still getting nothing on the needle. are these units 0 ohms empty and 30 full? i will test tomorrow. also, does the guage have to be grounded or does it ground through the housing? there are only 2 posts and most guages i've seen by re-searching this have 3 (ignition, ground, sender). thanks-DVZ | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | you are correct. 30 ohm full 0 ohm empty It grounds to the housing Credit to Jimmi V A few months ago I could not get my new 12v replacement gas gauge working. After reading Jimmi V's post I cleaned paint from the housing, I bench tested it and it works. | | |
