2 members (baldeagle, 78buckshot), 61 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#727395 03/07/2011 12:49 AM
Has anyone used the door lower "inside/outside" replacement panels available from LMC & Classic Parts? Are these quality panels? I would like to use them for my 65 C10 doors....
Thank you
Tim
On My frist door I used the deluxe panels from Clasic and it fit OK with a little work on the other door I made my own after building my own brake press so I could bend 16ga. All of the panels need some "fitting" to make them look good.
Good luck,Pete
My experience is the same as Pete, they need a little tweaking. but if you don't want to make your own, they are a good deal. I would use them again.
Thank you both for the reply Sirs!
