1 members (Southerntruck),
73
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | Has anyone used the door lower "inside/outside" replacement panels available from LMC & Classic Parts? Are these quality panels? I would like to use them for my 65 C10 doors....
Thank you Tim
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | On My frist door I used the deluxe panels from Clasic and it fit OK with a little work on the other door I made my own after building my own brake press so I could bend 16ga. All of the panels need some "fitting" to make them look good.
Good luck,Pete | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | My experience is the same as Pete, they need a little tweaking. but if you don't want to make your own, they are a good deal. I would use them again. | | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | Thank you both for the reply Sirs! | | |
