| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | My headlamps are out, all four of them. The book says that there are two fuses, one for headlamps and one for everything else. I removed the switch, and it only has one tiny fuse on it. I checked it, and it shows continuity. I can't find the other fuse.
Where did they hide it?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there are 2 bi-metal overload fuses on the switch, the springy tab contacts on each side - unlikely they'd both go at the same time .... if you have the accessory fuse panel might be one on it - wouldn't be unheard of for all 4 to burn out at once  other wise I'd suspect wiring someplace, do all the other lights work? Bill | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Dont forget to check the dimmer switch. When they go bad, the headlights wont work. | | |
