1 members (baldeagle), 91 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#727750 03/08/2011 12:07 AM
My headlamps are out, all four of them.
The book says that there are two fuses, one for headlamps and one for everything else.
I removed the switch, and it only has one tiny fuse on it. I checked it, and it shows continuity.
I can't find the other fuse.
Where did they hide it?
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #727753 03/08/2011 12:14 AM
there are 2 bi-metal overload fuses on the switch, the springy tab contacts on each side - unlikely they'd both go at the same time .... if you have the accessory fuse panel might be one on it - wouldn't be unheard of for all 4 to burn out at once wink other wise I'd suspect wiring someplace, do all the other lights work?
squeeze #727759 03/08/2011 12:24 AM
Dont forget to check the dimmer switch. When they go bad, the headlights wont work.
