2 members (Johnnydog, 78buckshot), 60 guests, and 2 robots.
Topics128,060
Posts1,055,832
#727625 03/07/2011 5:10 PM
I am changing to a 73-87 C10 backing plate drum assembly larger brakes and 5 bolt axles. I rebuilt the original rearend 1965. It looks like I need a spacer between the flange and the drum backing plate. Where would I get this or will I have to make them ? The 65 rearend is like an inch narrower than the later one.
roofus #728468 03/10/2011 3:10 AM
You need to have the axles shortened and regrooved. That will correct the length difference.
Bill Burmeister
would the splines need to be legthened or just the axle shortened and c clip groove recut ?
