| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | any info out there from folks who have set(we'll say preset)the rake on the frame?
The truck is setting there bare with nothing but the cab, and the existing rear.
I will be welding in the IFS this weekend and setting the 350 down on the front end. to gain actual ride height on the front.
once this is done I want to drop the existing rear end and make ready for the 9inch. Point is I'd like to build to the rear end (setting on rubber) and set the appropriate rake...on the frame.
of course taking into account for eventual bed weight, gas tank (approx 20 gal) and spring compression to bring me to a final 3 to 5 deg rise. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Have you thought about air bags?
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | You should put the rear end in BEFORE you install your IFS. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | What kind of IFS are you welding in? What degree of rake are you looking for? Do you know what size rims and tire you are going to run? Hoping not to sound like a smart [censored], but do you have some guys helping you that have done this before? The pitfalls of JUST welding in a frontend are many. For sure, these guys are here to help but there's no substitite for an old grease monkey with an eyeball on the build. Good luck.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I agree with wbrowne, I put the rear end in before I welded my IFS in, not only that but I had the rear 4-link setup installed before I did the IFS. I had a mock up set of wheels on the rear also. I used a TCI IFS and followed the instructions, and called them with some questions a few times. Must have measured a dozen times on both the rear and front setup before I welded! | | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | You should put the rear end in BEFORE you install your IFS. If you don't mind...please give me your thoughts on this.. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I mocked up the rear first, bolted in the 4-link suspension, put the rear end, 69 Camaro 10 bolt in. Then I played with my measurements on the IFS. Made my markings, then took everything off, put the frame on blocks with the same height and tack welded the ifs in. Put everything back on the frame and checked everything out before final welding! That's how I did it. It worked for me. Check out the photos on my site, not many of the frame, but you can see our ride height and the centering of our wheels in the fender openings. I am sure others have done it differently, but it worked for me! Coach Frank | | |
