3 members (farmallb, DaveV, Peggy M), 47 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#726426 03/04/2011 2:42 AM
any info out there from folks who have set(we'll say preset)the rake on the frame?
The truck is setting there bare with nothing but the cab, and the existing rear.
I will be welding in the IFS this weekend and setting the 350 down on the front end. to gain actual ride height on the front.
once this is done I want to drop the existing rear end and make ready for the 9inch. Point is I'd like to build to the rear end (setting on rubber) and set the appropriate rake...on the frame.
of course taking into account for eventual bed weight, gas tank (approx 20 gal) and spring compression to bring me to a final 3 to 5 deg rise.
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
http://flic.kr/p/8RQvKZ
Have you thought about air bags?
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
You should put the rear end in BEFORE you install your IFS.
wbrowne #726617 03/04/2011 3:04 PM
What kind of IFS are you welding in? What degree of rake are you looking for? Do you know what size rims and tire you are going to run? Hoping not to sound like a smart [censored], but do you have some guys helping you that have done this before? The pitfalls of JUST welding in a frontend are many. For sure, these guys are here to help but there's no substitite for an old grease monkey with an eyeball on the build. Good luck.
beltfed #726966 03/05/2011 4:11 PM
I agree with wbrowne, I put the rear end in before I welded my IFS in, not only that but I had the rear 4-link setup installed before I did the IFS. I had a mock up set of wheels on the rear also. I used a TCI IFS and followed the instructions, and called them with some questions a few times. Must have measured a dozen times on both the rear and front setup before I welded!
wbrowne #727463 03/07/2011 3:45 AM
If you don't mind...please give me your thoughts on this..
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
I mocked up the rear first, bolted in the 4-link suspension, put the rear end, 69 Camaro 10 bolt in. Then I played with my measurements on the IFS. Made my markings, then took everything off, put the frame on blocks with the same height and tack welded the ifs in. Put everything back on the frame and checked everything out before final welding! That's how I did it. It worked for me. Check out the photos on my site, not many of the frame, but you can see our ride height and the centering of our wheels in the fender openings. I am sure others have done it differently, but it worked for me!
Coach Frank
