| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I'm going through the brakes on my 58 4400. I've searched online, offline, and in between the lines and cannot location a master cylinder rebuild kit or front and rear wheel cylinders.
Could someone tell me where I can find them?
NAPA doesn't list them online, but guess I can try one of their stores.
Master cylinder bore 1.25 Front cylinders, .875 Rear cylinders, 1.50
Thanks, Victor
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2007 Posts: 9 New Guy | | New Guy Joined: Feb 2007 Posts: 9 | www.raybestos.com master cylinder #mc21698 wheel cylinders rear new wc 18196 and wc18197 front kit wk129 john | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy VEW, I found everything at Rock Auto Master cylinder kit Raybestos p/n MK33 $16.24 Master cylinder Raybestos p/n MC21698 $125.79 Front wheel cylinder kit Raybestos p/n WK129 $3.12 Rear wheel cylinder kit Raybestos p/n WK147 $10.16 Rear hweel cylinder Raybestos p/n WC18196 [forward position] $27.79 Rear wheel cylinder Raybestos p/n WC18197 $27.79, hope that helps | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Thanks John.........much appreciated!!!
b/t/w love your truck!!!
Victor
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Thanks 3B.
I don't know why, but I just didn't have Raybestos as a link for my brake parts. Do now!!!
Victor
