Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, 1 invisible), 145 guests, and 5 robots.
Topics128,288
Posts1,058,581
Members48,492
#727141 03/06/2011 2:34 AM
Can a Closed or Torque Tube rear axle be converted to accept a OPENED or conventional driveshaft???
The entire torque tube/center carrier assembly can be replaced, using the same axle tube housing by bolting in an open driveline carrier from a later-model truck. The pivoting attachment points between the axle tubes and the spring mounts must be welded in the proper position to establish the right pinion flange angle when the carrier swap is made.
I have a 1954 3100 w/a beefed up 261 engine--presently retained the closed drivetrain w/6 lug stock rear axle.. I want to install a 1985 S-10 T-5 trans. Can my existing rear be adapted to accept a conventional driveshaft??? By the way this the GREATEST FORUM IN THE WORLD!!!!!!!!!!!!!!
The rear axle itself does not necessarily need to be changed, but there's no practical way to adapt the torque tube to open-driveline configuration. If you unbolt the entire torque tube and center carrier assembly, a 1955-59 open-driveline center chunk can be substituted for the torque tube setup. Since the torque tube axle housing is designed to pivot where it attaches to the leaf springs, this pivot must be immobilized by welding up the pivots. Most people choose to weld the pivots before disassembling the original driveline to use the torque tube as a holding jig for the housing. I think the only stock gear ratio available is a 3.90:1, with a 3.55:1 gearset available from aftermarket vendors. The 3.90 works well with the T-5 overdrive, giving a good combination of acceleration, top end speed, and fuel economy.
Jerry, you are a tremendous help. I have a 1957 3100 rear axle assembly drum to drum (6 lug) available to me. How hard or what would i have to do to make this to the T-5?????
If you've got the complete unit, I'd suggest using it all. You'll need to get a driveshaft built that's the correct length, and I think there's a little issue with getting the rear wheels centered in the fender opening. Somebody suggested reversing the spring main leaves, which puts the center of the axle tube close to the right location. I've also been known to add a plate on the spring perch of the rear end with spring center bolt holes drilled 1" apart to let me fudge a little on the wheelbase of a dirt track car. A simlar arrangement could allow you to adjust the wheel well centering. Once the wheel-to-fender relationship looks right, then have the driveshaft made to whatever length you wish. Make sure the slip yoke that goes into the back of the transmission has enough room to move in and out as the suspension makes its normal up and down movement without bottoming out in the transmission.
thanks Jerry
