Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (1955 1 Series, 3B, Jay R, Wayne67vert, Phak1, DaveV, Hush), 123 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#726983 03/05/2011 4:44 PM
Can someone send me a picture of how their throttle cable links to the carb. 1952 chevrolet 3600.
Joshua #726994 03/05/2011 5:02 PM
Joshua,
Maybe someone will post a clear picture of the linkage. Do you have a 1952 engine? Your carburetor might not look the ones in the diagrams below but the linkages are the same.
There is a rod that goes straight down from the throttle-arm lever (3.759) near the base of the carburetor to a pivot-lever on a post on the side of the block (3.580). A rod goes from that pivot lever to the accelerator pedal. There is no cable (but, there is a spring, 4.459, attached to the "down-rod" and to a clip held by a pan-bolt as shown in the second diagram).
