| | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Can someone send me a picture of how their throttle cable links to the carb. 1952 chevrolet 3600. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Joshua, Maybe someone will post a clear picture of the linkage. Do you have a 1952 engine? Your carburetor might not look the ones in the diagrams below but the linkages are the same. There is a rod that goes straight down from the throttle-arm lever (3.759) near the base of the carburetor to a pivot-lever on a post on the side of the block (3.580). A rod goes from that pivot lever to the accelerator pedal. There is no cable (but, there is a spring, 4.459, attached to the "down-rod" and to a clip held by a pan-bolt as shown in the second diagram). | | |
